Ai Heads & Cam First Start Video!
Finally got the motor put back together just wanted to share a few brief sound clips for the LT1 crowd. Videos are rather short as there was no cooling system or accessories installed, was just a test start. Hope to have it on the road once the snow dies down in the next few days. Mod list is below!
Stock Short Block - Heads Milled for 11:1 Compression
Ai 200cc Full CNC Porting & Components
Ai Hydraulic Roller Camshaft - Ai 228 / 234 - .614" / .614" - 108 LSA
ARP ProSeries Rocker Studs - 7/16"
Comp Cams Ultra Pro-Magnum Rocker Arms - 1.6 Ratio
GMPP 12499225 Hi-Performance LSx Hydraulic Roller Lifters
Ai One Piece 4130 ChromeMoly Hardened Pushrods 5/16" & .080" Wall Thickness
.026" Head Gaskets
ARP 134-3601 High Performance LTx Cylinder Head Bolt Kit
Full Porting for GM LT Manifold (includes inlet porting)
BBK-1544 Power-Plus Series Throttle Body 58mm
TFS-89036 TrickFlow 36lb/hr Fuel Injector Set
Clear Image Automotive 304 Stainless Gen-II Tri-Y Headers/Export Pipes into Spintech Pro Street 9000's
Meziere HD Electric Water Pump
March Underdrive Pulley
8MM Magnacore Wires/MSD Cap&Rotor with Stock Opti Internals
Cloyes Factory Replacement Timing Set
Walbro 255LPH Pump w/Racetronix Harness
Isky Racing Hardened Chrome-Moly Guide Plates
F-Body 3.5" MAF
95 T56 Trans/ Spec Stage 2+ Clutch / MGW Short Throw Shifter / 3.73 Rear End
PCM Tuned by Alex@PCMPerformance
Thanks For Watching! More to come in spring time.
.026" Head Gaskets
F-Body 3.5" MAF
Haha! At first I was like oh god...not again. Too funny!
Thanks to everyone for the positive comments I'm very excited to get it on the road this spring for some ET's, dyno numbers and overall beating on the street!
LMAOO!!!! That was my mother , I had to use her driveway for the project. At the start of the video you can hear her say " You're going to make the neighbors insane" Haha, she was like " can we turn it off now? " " Is it over yet? " "Ok, thats enough now turn it off " ... Too funny.
