EGR issues, can I just disable my air pump/ EGR instead of removing/ blocking off.
As the title says, instead of using block off plates can I just use tunerpro to disable my EGR and bypass it that way? Right now I don't want to delete EGR/ AIR and was wondering if I could do this to get my gas mileage back?
If anything, I think a properly functioning EGR would help your gas mileage. But if you were throwing an EGR code I'm guessing your PCM was responding to the perceived problem by making your car run rich and killing your mileage. How good is the tune? Any pops when you rev up? Popping/gargling noises on decel?
Engine runs very rich, I can smell the gas on a cold start and it pops/ crackles a decent amount on decel. Tune is good but I've been chasing a ghost knock issue that I've had since I started datalogging last summer, I think its the EGR issue causing the knock. Getting up to 10* at WOT. Thats with the LT4 knock module too.
