94 lt1 with msd opti vent question?
Old 03-30-2014, 12:00 AM
2fast4u1989's Avatar
Default 94 lt1 with msd opti vent question?
I have a 94 lt1 and the previous owner installed the msd opti. he routed the vacuum line the runs from the bottom of the opti to the intake manifold, but that hose cracked to im going to replace it this week. also I noticed that he did not run the fresh air vent hose (the one that is supposed to go to the inlet). do I have to run that fresh air hose or can I cap it on the msd unit?
Old 03-30-2014, 09:06 AM
shbox's Avatar
Capping the fresh air vent might cause a vacuum build up in the opti which can suck the cap in. You need that open and run to the right place. MSD instructions show where it all goes.
Old 03-30-2014, 07:17 PM
DUDCOUPE's Avatar
Mines just chillin not hooked up to get fresh air from my cai
Old 03-30-2014, 09:33 PM
shbox's Avatar
That's fine if you want to draw dirty air into your opti. Not the optimal setup.
Old 03-30-2014, 10:37 PM
where can I find the little piece that hooks into the hose and then into the inlet? done have it at all. any reviews on the chandler opti?
Old 03-31-2014, 08:40 AM
96TransAmboosted's Avatar
Chandler opti = fail. Ac delco or MSD but you already have the msd so run the line from the cap to the intake track then rn the one from the opti to the intake manifold with the check valve. Call it done
Old 03-31-2014, 01:47 PM
DUDCOUPE's Avatar
I do have one of the little breathers that plug into a lets say 1/4 pipe on it
Quick Reply: 94 lt1 with msd opti vent question?
