turbowerx scavenge pump wiring
Old 07-21-2014, 08:20 PM
vettezilla's Avatar
Default turbowerx scavenge pump wiring
I installed a base model Turbowerx "Spartan" scavenge pump, now according to the manual a 10amp fuse should be fine however it seems to pop them... should I try a 15 or 20 amp fuse? Will this cause damage and what does anyone else use for a fuse on these pumps
Old 07-21-2014, 08:39 PM
Man-Crush Warning
Shownomercy's Avatar
LS1Tech 10 Year
Mine is a 70amp relay, and a 30 or 40 amp J fuse.
Old 07-21-2014, 09:08 PM
vettezilla's Avatar
Mine is a 100amp relay, and a 30 or 40 amp J fuse.
At the risk of sounding like an idiot why would you wire in a relay.... on mine I wired into an existing slot in the fuse block that was available for switched on power... is it better to wire it the way you did
Old 07-22-2014, 07:10 AM
Man-Crush Warning
LS1Tech 10 Year
Uh, cause none of the wiring in a stock fuse block is really capable of running a pump like that continuous.
Old 07-22-2014, 03:05 PM
vettezilla's Avatar
That would explain why mine blew after 20 minutes of use... need more info on your wiring setup... you run to a factory relay or did you run your own, is it set up so when the car is on accessory II mode it turns on
Old 07-23-2014, 08:35 AM
Man-Crush Warning
LS1Tech 10 Year
Maybe you should consider taking the car to a performance shop.
Otherwise, google automotive relay. Learn.
I run all my stuff via one of these
http://www.leashelectronics.com/Heav...anel-8RBHO.htm
Manual triggered on/off.
Quick Reply: turbowerx scavenge pump wiring
