Lt1 wiring options
Lt1 wiring options
I am swapping a lt1 into my 80 El Camino, A question for the people who have done swap before Should I use the under hood fuse block or an after market one and why.
LS1Tech Sponsor
However, the factory one will work for you. Just will be more bulky and have more unused items in it.
If you decided to get a new harness, our harness will include a grommet and a fuse block with the options you need.
But you can still use what you have! Our small DIY kit is only $75.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181429513227&ssPageName=STRK:MESE:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181432535725&ssPageName=STRK:MESE:IT
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
I put one in a 92 chevrolet truck a cuople of years ago. I used the LT1 fuse box and cut the bracket off the donor car, welded it somewhere in the engine compartment. It all worked but when I got finished it had a lot of extra wiring and as said above about 3 times more fuse/realy box then I needed.
I put an LT1 in my 98 blazer and utilized the factory blazer underhood fuse relay box. if I were doing something like your older el camino, I'd get one of bills kits listed above. It would come out way cleaner than using the factory box.
