wrong radiator?
Old 10-29-2014, 05:41 PM
LT1Bird97's Avatar
Default wrong radiator?
I bought this radiator http://www.genesisautoparts.com/prod...w2NBoCJKfw_wcB
When I compare it to the one I pulled out, the 2nd to bottom hole on the passenger side is covered with metal.
Did I get the wrong one or something?
http://shbox.com/1/radiator_A4.jpg
Its the water pump inlet that has a piece of metal blocking it
Old 10-29-2014, 09:29 PM
LT1
LT1's Avatar
Can you take a picture so we can see how its blocked?
Old 10-29-2014, 09:48 PM
shbox's Avatar
Are you sure you are not just seeing the metal trans cooler that is inside the passenger tank? Coolant should flow around it and the hole to the hose should not be "blocked".
Old 10-30-2014, 11:20 AM
LT1Bird97's Avatar
thats most likely exactly what im looking at I have a manual so my old one didnt have a trans cooler. Good to know
But I kinda got a bigger problem now....I forgot a wire and I cannot for the life of my figure out where its suppose to go
http://imgur.com/a/mcqGG
Hopefully one of you more experienced guys can tell me where to plug this back into
Edit: Wire says "29 PED" on it if that means anything
Old 10-30-2014, 02:28 PM
LT1Bird97's Avatar
Figured it out, guess I missed the water pump temp sensor
Quick Reply: wrong radiator?
