nitrous 60 foot questin
I just now watched the video. It looks like a shock problem to me.
nitrous2 is right; it's unloading and spinning after the initial hit.
I wouldn't change converters or do anything else until you get the suspension under control.
What do you have for shocks? front and rear
revmax converters are fine even for nitrous.... they do have billet pieces as well though.
From the video it looks like the weight is shifting rearward then back forward, causing it to unload. you do spin after it unloads. not only is it shifting front to back but also side to side. Maybe an airbag in the right side coil. What rpms are you launching at and what rpm do you have your window switch set to spray?
