Need info asap pleaseeeee someone..
Old 11-17-2014, 12:52 AM
DevinG-BodyRobinson's Avatar
Talking Need info asap pleaseeeee someone..
Hi Im Devin I have a 1986 Monte Carlo Ls. I plan on putting in a LT1 I got out of a old police interceptor, I got the whole set up from wiring to the posi trac. But my biggest question is how to convert the LT1 to carb and HEI Distributor? I seen a intake by holley that would allow it. But far as the Distributor im lost.
Old 11-17-2014, 07:56 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Hey Devin, welcome to LS1tech!
Sounds like a nice project.
As I recall, this vehicle came with the 4.3L V6. It had fuel injection.
You should be able to get a HEI distributor from Ron Davis that'll work for you. http://performancedistributors.com/
Exhaust headers and motor mounts for the 5.0 SS version is needed also.
I don't think the Caprice rear end will fit the Monte.
Do you have any wrenching experienced friends helping you with this?
Old 11-17-2014, 09:57 PM
Catmaigne's Avatar
G-bodies that aren't the Grand National will have the 7.5" 10 bolt so if your posi is from a G80 Caprice then it will be 8.5" and won't fit. I know it's not that hard to put the B-body rear in a Monte but the width will be different. You'll need different length control arms (might just be lowers, not sure).
Old 11-20-2014, 05:15 AM
bufmatmuslepants's Avatar
Gmpp makes a carb LT1 intake manifold, its still on summitracing.com last I saw. But the biggest question I have for you is why do you want to go carb and HEI instead of keeping the fuel injection if you have everything already? You would spend more on a carb, distributor and intake manifold than you would tuning up the original setup.
Quick Reply: Need info asap pleaseeeee someone..
