-8 Feed on a stock Sender??
Old 12-30-2014, 11:02 AM
glocklimited9's Avatar
Default -8 Feed on a stock Sender??
Hey guys, finally getting back going on my 96 Ws6 and im wanting to build a Fuel system with a -8 feed, -6 return
Ive seen the adapters to go from the factory sender to -6, but havent found one from sender to -8
Anybody have a setup like this?
Old 12-30-2014, 04:33 PM
Kevin Blown 95 TA's Avatar
You can get a 3/8 tube to -6 adapter and then adapt up to a -8 (top fitting in photo) or I've also seen a 3/8 tube to -8 adapter listed at Summit, but they show the wrong picture along with it so not sure I would order it without confirming what it is. Also with these, you would have to cut your line and tighten them on - you don't just snap them on like the usual fuel fittings.
http://www.summitracing.com/parts/ea...6erl/overview/
Old 12-30-2014, 10:07 PM
PA94Z's Avatar
3/8 to 8an - http://www.swagelok.com/search/find_...00-6-8AN&item=
5/16 to 6an P/N 5780 - http://www.purechoicemotorsports.com...rod/prd264.htm
Quick Reply: -8 Feed on a stock Sender??
