Car Not Running - Need Help
#42
If you didn't remove every spark plug, I'm not sure how accurate the compression results would be. I believe there would be some impact upon your readings.
My money is also on the optispark.
#43
I also have always had the feeling it was the opti, but I wanted to make sure. I just ordered a new MSD unit and will do new wires while I am at it. It ships out today so I hope to have it put back together and running this weekend. I will let everyone know how it goes.
#44
Good luck with the MSD, but if it's not too late I would cancel the order and get a Delphi or AC Delco. MSD optis may be marginally better than other aftermarket junk.
#46
Sounds like hearsay, I have actual experience with the MSD unit. I've spun my motor up 6500 rpm making power numerous times Driven through 2-3 inches of standing water, snow, 10 degree or below temperatures, 90 degree plus humid days, etc. For over four years, this Opti has never skipped a beat. I better go knock on wood now. I'm just saying
#48
#49
I will add in my personal experience, my stock AC delco took a dump at around 70K, I had a gently used (supposedly only a few thousand miles on it) MSD I paid $200 for that had a sporadic misfire at high RPM. I ended up taking it off and putting on a cheap "dura last gold" auto zone POS, that ended up with a highly sporadic low RPM misfire/stumble/backfire, until it failed 2K miles later, I decided to give MSD another chance, and paid MSD $137 to "rebuild" the old MSD (I'm 90% sure they just sent me a brand new one, the case was not scuffed up/scratched like the old one) and send me the vent hoses that were missing. My car had never had a vented opti until a couple months ago...
Biggest advantage to MSD is they stand behind the product and will fix it if something happens out of warranty (even it you didn't buy it new), worst case scenario you are out another $137....AC delco makes no such promises. Something to consider which is certainly not hearsay.
#50
Damn, maybe I didn't do enough research, but I was under the impression that MSD opti's were considered as good as delco/delphi. Well, too late now, let's just hope it works and holds up!
#51
So on the new opti instructions it says to take the cap off the old opti and see the rotor position and make sure the new one lines up correctly. Do I really need to do that? If I put the dowel pin in the right hole, shouldnt that automatically line up the rotor?
#54
Ok, so last night I left everything the way it was and just hooked up the new opti. Car started (yay!) and ran much better, but not quite right yet. I didn't fully expect it to because I still had the MAF and all that stuff unplugged and still have the water pump off. I am going to take this opportunity to go ahead and put fresh plus and wires on just to be safe. Hopefully once I put everything back together and let it run for a little bit, it will be able to work out the kinks.
#55
#56
Injectors can be checked for signal with a noid light, or you can just pull the fuel rails and watch to make sure they all spray but don't leak when you crank the engine.
#57
So this is waaayyy late, but I figured I would update this thread. I replaced the Opti and put new wires on as I found out one was cracked. The car is running now, had to bleed the coolant system for a while, but finally got it figured out. Now it is pretty much running, but I think I still have a vacuum leak somewhere. Sometimes when it idles, it will idle high and start revving up around 2k rpms. And sometimes when I am driving, it has a bad hesitation until I give it more throttle. Almost seems like it will cut out when I am cruising sometimes. Hope to figure out that mystery soon.
