Advice needed on replacing pass side wires and plugs on 94 LT1
Old 01-25-2015, 05:31 AM
Notplayn's Avatar
Default Advice needed on replacing pass side wires and plugs on 94 LT1
Was wondering how you guys replaced the spark plug wires and plugs on pass side LT1. It's a 94 formula firehawk with factory manifolds. Remove pass side motor mount bolt and jack engine or pull accessory bracket? I already have alt off and pwr steering pump loose. Thanks
Old 03-10-2015, 03:44 PM
94formular's Avatar
I went in from bottom had no problems at all I would recommend that, took bout 2 hours doing other stuff as well didn't have too take anything off to remove plugs and wires
Old 03-10-2015, 11:35 PM
VoyagerCamaro's Avatar
I did mine from the top. Just take your time and go slow. Also one at a time. I would go back to front because the one closest to the front of the car sucks like 8 bitches on a bitch boat... The hardest part for me was getting them in the stock routing. Will all those PITA retainers, clips and what not. Good luck!
Old 03-11-2015, 02:07 PM
chaney1974's Avatar
be thank full you do not have headers! you have it easy with stock manifolds
Old 03-11-2015, 02:12 PM
What are you smoking brother? I have pacesetter mid tubes and did the over the valve cover routing and it's a walk in the park. What headers do you have?
Old 03-12-2015, 06:08 AM
leadfoot4's Avatar
I fully realize that these cars are getting pretty old, now, so rust is an issue, even for cars that weren't driven through the winters. Having said that, the two times I changed the plugs on my '96 Z, I dropped the "Y" pipe, which took about 20 minutes (no rust issues), then changing the plugs, except for #2, was a breeze. #2 is a PITA, because of the A/C lines that surround it.
Old 03-12-2015, 06:47 PM
Birdracing's Avatar
On my 94 Z28, with LT's i went from under the car i had to remove the alternator to get at the last plug. Other than that it wasn't to bad, my car is a US rust free car that is always garage stored, so i had no problems there.
Old 03-13-2015, 12:56 PM
kris72079's Avatar
24x conversion FTW!
Old 03-14-2015, 07:54 AM
chaney1974's Avatar
BBK mid tube back two are a real Treat
Old 03-14-2015, 07:57 AM
chaney1974's Avatar
BBK mid tubes the back two suck *****!
Old 03-15-2015, 07:23 PM
95_TA_USMC's Avatar
Honestly going from top or bottom, whichever suits you best. Spark plug socket and correct size wrench and I never have many issues with them. But I have had a few get me in the mood to throw plugs out the window...
Quick Reply: Advice needed on replacing pass side wires and plugs on 94 LT1
