Versa Fueler
Old 02-23-2015, 03:32 PM
moehorsepower's Avatar
Default Versa Fueler
Just wanted to let you all know of an issue I had and found the problem, My car was idling then just shut off, Had fuel pressure, plenty of spark, so I started checking, the MAF, TPS, PCM, harness ect, then realized I had no injector pulsewidth, of course I thought the dam opti, I but then I decided to check the versa fueler, (Driver box for my low impedance 96llb injectors) I bypassed it and she started up, So if you are using any type of driver for low ohm injectors and you loose pulsewidth, you might want to check this first and save you a lot of headaches..
Quick Reply: Versa Fueler
