Custom Fit Electric Water Pump and/or Nitrous Harness
Hey Guys and Gals,
We already have built a few EWP harnesses. We now have the connector for the CSR pump, and already had the connector for the Mezire Pump.
So we can build the EWP harness so that it is Plug and Play with the Pump and the sealed relay and fuse holder are mounted discreetly behind the PCM on the firewall.
We can also build custom fit nitrous harnesses also. Just haven't really marketed it.
The reason I am making the announcement about the EWP harnesses and the Nitrous harness is I see so many products out there for wiring these in, but unfortunately they are not a good quality item the majority of the time.
On both of these harnesses you will find that most other options out there will use regular primary wire and not high temp TXL wire. Furthermore, they will use cheap grade copper, and cheap knock off connectors and terminals.
So, post up guys and gals if you would be interested in something like this. And if you are, well we will build them.
Bill
Bill
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
