Another Water Pump Thread...
#42
If anyone has a problem with the facts I provide (yes they are facts, refusal to accept them as fact doesn't change that they are facts) because I don't want to give them a lesson in high school physics, that's their problem.
#43
My observations is the EWP guys are far more defensive than the mechanical guys. Case in point, in two threads (this one and mine) EWP guys are in here spewing their rhetoric to guys that want to keep their mechanical set up. These EWP guys dont road race, but you know, they have one, so they know better.
Meanwhile, the mechanical guys aren't saying EWP suck. It's the EWP guys saying the mechanical sucks.
#44
The data is there (on both sides of the argument), you have to actually see it. I'm not going to find it for you. I've researched this, your turn to do it your self.
My observations is the EWP guys are far more defensive than the mechanical guys. Case in point, in two threads (this one and mine) EWP guys are in here spewing their rhetoric to guys that don't want to keep their mechanical set up. These EWP guys dont road race, but you know, they have one, so they know better.
#45
#46
There's a reason I named my thread "another water pump thread..." Haha it's all personal opinion if you ask me. Ill stick with a mechanical for the most part, unless I have a strict strip car which will probably never happen cause I'm all about the street, trailers are for ******!
#47
#52
So I seen that the water pump drive seal was the one that was leaking, and a lot as I had stated in my original thread post, holy gunk batman look at that opti!
I also found out the DS valve cover was leaking at the front, hence the oil over there, so today I am putting the seals on! But first I'm cleaning the all the **** that's just gunked and baked on the engine opti spark plug wires etc etc. btw so no one freaks out, I took these pics after I had already pryed the water pump seal out with a screw driver.
#53
Negatory. Go re-read that thread. My position is purely factual. I'm sorry you're having a hard time understanding that. Any personal issues I've had on that thread were with a certain individual using personal insults when he didn't like the facts provided.
Having personal issues is not something for a car forum, we like to keep things factual. Most understand an ewp's place, you do yet you don't? Maybe its your reading comprehension?
#54
You lied a bunch, you were called out on it, you provided nothing factual. If you re-read the thread, you will see I said nothing towards the normal ewp bs like increased cooling capacity etc. You thick head and shallow mind created your own argument and you have yet to realize this. Maybe its a learning disability, I don't know.Having personal issues is not something for a car forum, we like to keep things factual. Most understand an ewp's place, you do yet you don't? Maybe its your reading comprehension?
Come here to Arizona, let's race. Leave it on the track.
#56
Man-Crush Warning
I am asking for proof or actual evidence that during autoX or road racing, an EWP flow rate will not be enough to support the ECT. Up until now, both of these train wreck threads bicker and bicker about flow rates with only correlations that a lower flow rate is enough to cause overheating.
About the trailer comment, I'll drive my heap to the track and wait for you in the return lane cupcake.
#57
Well after hours of cleaning and scrubbing with rags, she's clean! As I can get it at least lulz. All that's left is remove the crank hub, then opti and I'll be putting on the new seals. Went ahead and put a new water temp sensor on my water pump, cleaned it as well.
The opti is visible again!
Scrapped off the old gross baked on gaskets
All clean
Cleaned the WP, installed new temp sensor with some Teflon sealer. Not to shabby for practically 160k mile car.
All clean
#58
BMX is parting out his car for "business expansion" guess he knew one day a car with a MWP would out run his.
#59
I am not trying to argue flow rates between EWP and MWP. I won't be the one to prove science wrong.
That's a legitimate question. IIRC, the LT1 flows 66GPM under sytem pressie and resistance, the LS1 is over 120. There's a reason GM targeted those flow rates.
From all the research I've done, auto x should be fine with an EWP for most courses and locations. Road courses with long open track periods have always recommended MWP from all manufacturers and serious racers. There's a reason Meziere makes mechanical pump's when they are known for EWPs.
I think in his application the EWP is great. Hell, I'd do it if I planned a street/strip car.
#60
Man-Crush Warning
A stock pump is a fixed impeller and constant displacement (for teh sake of agruement here), so making something that works at idle may be overkill or unneeded at WOT.
Granted I do not take highways at ~120mph but, still curious on if cases ACTUALLY exist where an EWP car had to switch to MWP.
