Timing, CC503, stock cubes, ported heads
Old 08-20-2015, 08:01 PM
camar0corey's Avatar
Default Timing, CC503, stock cubes, ported heads
Just wondering where people are at for all in timing with the CC503, stock cubes, ported heads.
Scratching my head here as my tune is at 30. Maybe the tuner was worried about the injectors? Whole time at WOT car is at 12.62 on the wideband, from 6000-6500 RPM I am at around 80-82.5% duty cycle with the 30 LB. red tops.
Thoughts?? I don't plan on winding this thing out for long periods of time, should I be able to get away with more fuel/timing??
Just wondering what other people with the same general mods are around, I've heard 36-38 is the norm for timing.
Old 08-20-2015, 09:01 PM
VoyagerCamaro's Avatar
I have a project motor, stock C.I. LT1, home ported stock heads (no flow numbers) CC503 blah blah blah, you get it. I run 38* of timing but I haven't had the engine in the car yet.... Still playing with the advanced curve... So far at 38* my motor safely makes it's peak power with 12.6 AFR. LT1 PCMs add 2-4 degrees of what's in the spark table. Keep this in mind. Is this the new 24x car you picked up for free?
Old 08-21-2015, 05:11 PM
No its the 94 Z28 I've had since 2004, but it also has the 24x system. Good to know about the LT1 PCM though, never heard about that.
Edit: The free car is completely stock internally, still has the stamped 1.5 rockers and original springs in it even.
Old 08-21-2015, 06:28 PM
Dirty_Bird's Avatar
Plugs tell all
Old 08-22-2015, 05:31 PM
I tune my car now, because it's only a bolt on motor, however I took my built mildish street 503
motor to my friend Nathan a few counties away, I never knew the whole 2-4* in the spark tables deal either until he informed me of it. I trust him with LT1's it was his first car and he still drives it
to this day, it's built now of course lol.... He specializes mainly in LT1/LT4 tuning but he does anything LS as well.
Quick Reply: Timing, CC503, stock cubes, ported heads
