Can a faulty Knock sensor or Crankshaft position sensor?
I have a 1996 camaro z28 m6 and I I have lomgtube headers,ORY,and magna flow catback. That's all the mods. My question is can a bad knock sensor or crankshaft position sensor cause a knocking coming from the engine? Every time I start it up it knocks and as I accelerate it knocks louder. I just hope it's not a spun bearing.
A video would help here. Engine knock (detonation) doesn't sound like someone knocking on your door, rod knock does though. Engine knock sounds more like shaking a can of rattle can paint.
A knock sensor will not cause knock (but if it's faulty it might not prevent it).A bad crank position sensor could, but it'll more than likely just barely run if it runs at all.
#1 https://youtu.be/r9-xoaIJmFY
#2 https://youtu.be/BCsiFMwIbo8
That sounds really bad. Pull the valve covers and look for anything obvious. Unfortunately, the speed of the knocking is basically in sync with engine rpms. That points to bottom half not top.
How's the oil pressure look?
There's the tapping sound, but also an underlying deeper knock. Sad to say it sounds like a rod bearing. If so, the more you run it, the more crank damage there will be.
As in bottom you mean?
Village Troll
I too am going to go with rod knock. Usually it the knock will be soft or disappear when the engine is revved and then become really loud as the engine is decelerating. Rebuild is your best bet, and soon. If you keep running it like that it will only cause more damage and more money will have to be spent.
Engine knock
@hrcslam paint can rattle!! That’s what I hear intermittently. Then goes into limp mode. Code is always misfire cylinder 1. 6 mechanics have failed to diagnose. $2200 later, a couple new coil packs, injectors, plugs, and new timing belt, problem is still the same. I think the noise I’ve heard is related. I thought it could be a sticking valve, You think it’s crank sensor? Can I just replace sensor or would I have to have the relearn procedure done?
A video would help here. Engine knock (detonation) doesn't sound like someone knocking on your door, rod knock does though. Engine knock sou more like shaking a can of rattle can paint.
I'm assuming it didn't knock prior to the install and when the car was dropped off, correct? Not trying to point fingers or anything, but hopefully the car wasn't "test drove" after the header install... Just a thought...
