First drive with the new cam and t56
Are you running the original OBD2 PCM or did you switch over to OBD1?
Email tune with data logging through Solomon is a pretty good way to go. He'll give you a base tune to start with and then fine tune it based on your data logs. Ultimately, probably not as good as a competent dyno tune though. (Good luck finding someone around here that knows what they are doing with an LTx.)
What part of IL are you from BTW?
I'm from Pekin BTW. You?
Outlaw..
3:23 gears with the T56 is really to high a gear. Slipping the clutch won't do it well.
4:10 is a great gear. At 80 MPH with a 27" tire my RPM is just under 2k.
On the street its a 4 speed. Fwy 5th and over 65 6th
When I did my A4 to T56 swap I had 3:73 and thought they would be good. They were "OK" but the 4:10 are perfect, IMHO.
If his car were a B-body, I'd say 4.10 gears.....hands down.
But lighter cars (F and Y-bodies) get along fine with less gear than out cars; so to that end, he may get along OK with the 3.73's.
What I do know, however.....is if it were my car, I'd most likely go with 4.10's.
KW
KW
Yeah KW the F & Y bodys are lighter. That's why I said 3:73 would be "OK"...but outside the weight diffrence between the F & B bdy the trans gear ratio is the same as my T56 and if running a 27 " tire I would go 4:10.
If running a Shorter tire on the F-body, 3:73 starts to get better. With a .75 5th and .50 6th on the T56 the 4:10's work well with either gear set
I run a 26" MT ET at the track and really like the way the car launches with the 4:10's but yeah I have a few pounds on the F-body :-)
No problem, you're welcome! If you already knew the issues were un-tuned related, why make a thread about it? Waiting a "few weeks" as you originally suggested and still driving it would most likely cause MORE issues; foul your plugs, potentially clog your cat if you have one, wash down the cylinders with excess gas, ect. Glad you took my "smart ***" advice and got a tune ordered! Any reputable tuner will make small changes and adjustments free of charge, they can simply email you updates and you can make the changes with a laptop or mail in the PCM again...
After my tune I still have a very strong gas smell, my timing is way off, but it does run better. I'll get into a new post here in a second about a few issues I'm still having. PCMFORLESS did the tune on a core computer if you're wondering.
IDK, my car was the exactly the same as the OP before my tune. It idled really low, kinda stumbled when taking off from a stop, and ran good when at highway speed. Not saying your wrong or anything because it could very well be something else , but I think its due to not being tuned. After my tune, the car really woke up!
Why would the cam cause a misfire code. running untuned didn't set a misfire code? I'm curious to hear more of this.
I'm assuming that you kept your injectors stock.
It's been years since I tried it, but if I recall correctly the CC503's driveability will be just fine on the stock tune.
One of the things I did when chasing my slight bucking off idle was to put the stock tune in it with only the injector settings changed(as I have 30# SVOs in it after the cam swap).
I don't recall any driveability issues on the stock tune. No idle problems, no bogging, etc. Was it making as much peak power? Most likely not, but I'm not so sure the tune is your problem.
The one thing I most certainly noticed(on both tunes) is that the torque production was lower on the bottom end of the rev range with the CC503, but from 3500 up the power is excellent...well exceeding what a stock LS would feel like.
So...I'm going to be a naysayer here and make a prediction that a tune will not fix your issue. I hope I'm wrong and my memory is failing me, but I don't recall any of the issues you are having on the stock tune when trying it on my CC503.
As a matter of fact, I'm running the stock ignition map if I recall correctly...with a slightly altered VE MAP where I lowered the VE around 10-15% from 3500 down and increased it around 5-10% above 3500.
So...you may have some troubleshooting ahead of you. However, when you get it sorted out, the CC503 is a good cam for stock heads. I've really enjoyed mine. Just make sure you open up the exhaust. I was running stock exhaust manifolds(after the cam swap to save money) for a couple of years then went to long tubes. I picked up 5mph and dropped 0.4 in the 1/8mile alone with just the long tubes. Picked up an easy 30hp.
TBH I'm hoping you're wrong. lol But I want someone to come over and check my rockers. I've only done this like twice now and I'm not very confident in my zero lash and preload.
If the issues I'm having aren't tune related then the rockers are the only thing it could be.
But it definitely runs smoother now. I use that word loosely.
Ok so here's where I'm at. I don't have any check engine lights. There's still a strong gas smell, not as bad though.
Stock injectors, LT headers, ORY pipe, no egr.
I was watching my engine data earlier and my car is pulling anywhere from -26* of timing to -40* of timing, the -40 being under light load. I don't have an LT4 knock module so I am wondering if this is why? I'm not hearing any pinging so I'm assuming it is from false knock from the RRs. Anyone have any ideas, to be 100% sure, or know of a legit way to get ahold of a LT4 KM?
Sorry for all the post in a row, didn't want to try a post everything at once.
If you are getting false knock, the knock counts should be going crazy. Does the PCM data show that number constantly incrementing during driving(normal or WOT)?
Rockers not lashed right could cause headaches. I prefer to set my rockers with the intake off. That way I can see the lifters and know where they are relative to the cam lobe position(so plunger compression does not fool me). Make sure you get someone to double check for you if your not sure.
My $.02 on PCM4Less....well not one I would use. I have always used Ed Wright. He has sold his shop/dyno but IIRC he still does mail order. Your mods are not much so a "good" mail order should work well. Certainly hands on Dyno is better to squeeze out every last HP.
you say your timing is "way off"...how do you know this...data log or?
cam installed right?
LT4 KM deals better with the harmonic range RR have. you seeing 40 degrees of timing being pulled...holly shiat. "something" not happy in motor. If you didn't lash the valves right, that will cause all kinds of drive-ability, motor running issues and would certainly cause timing to be pulled when you are on the gas
the 3:23 gears you can't lug the car, especially with a tune that may not be right or stock tune & T56 with the A4 tune.
Oh sorry lol, I meant the driveability characteristics was the same.
Scanner. Tried 2 of them just to be sure.
Everything seemed to go together right, and chain was installed dot to dot.
Haven't been able to drive it with new tune. Don't really want to until I get the timing sorted. But by "can't lug the car" you mean I need to give it more gas?
GM felt it necessary to change the knock module with LT4. From my understanding it was due to the roller rockers. As such, I would not run roller rockers without the LT4 knock module. I run a LT4 KM in my car.
Wished I'd bought 2 back in the day for my other PCM...so I would not have to swap it out when using the other PCM...but it is rare that I do that.
Having said that though, I think there are people who have no trouble with the LT1 module and rockers either.
