Take a look at the size of this cam for tha LT1
Comp Cams make a 220/230 int/exh dur. and 510/510 lift dur. at .050
what kind of cam would this be a stock Lt1 with full bolt ons.
I don't know much about cams, but I'm looking for a decent
driver with some power over stock, and NOT a lumpy cam.
I have some 1.6 magnum rockers I could use also.
its lopes and preforms. ive seen it in action. you should turn some good power with it too. i would also look at a comp cams 503. i think its 224/230 on .503/.510 lift. also since you have the pro mags you would get a little bit more lift from it, maybe some where around .525. makes better power and would idle a little bit smoother. the only other difference i see in the two is the 305 is on a 114 lsa and the 503 is on a 112.
That cam is choppy try a 222 226 on a 113 to 114.... If u want a good non to aggressive can for a daily driver stay away from off the shelf... Ask around and get a custom grind done it is worth the money..... Make sure your set up is correct thou heads, bolt ons and so forth....
for stock heads and stock valve train, i have the comp cams 218/224 .50 112 lobe sep. i have it in a automatic t/a and it performs great. has excellent power through the whole rpm range. the cam chops a little bit but is very streetable, no cam surges or idle problems. i had my idle set at 650 but i moved it up to 800 and it idled great at both settings.
Originally Posted by BRETTINATOR
Don't mean to rob your thread Spacecity but are you in Clear Lake by NASA?
you would not happen to have a harmonic balancer pulley I could use
for a few minutes do you?? I have the motor out and I am gonna spray
my engine bay. For the meanwhile I will do a gasket overhaul. I cannot get
my H/B off.
Originally Posted by 1_badt/a
I got the same cam in my t/a, its running 12.40's-50's all night w/o tuning.
is it real lopey?? you have a part ###??? I want something
with just a slight lope, very slight.
Actually, there was a local guy with the CC305 and I thought the two cams sounded remarkably similar.
Location: Somewhere between Auburn, AL and Columbus, GA
I had the cc305 in my 97 back when i still had my car. I had mine ground on 112 when i ordered it because i wanted the sound. I absolutley loved it..I was running hooker longtubes, no cats, cutout and a flowcrapper in the back and it sounded awesome. You could smell my car but i had a cutout and no cats so thats why.
