Anyone ever installed an ls1 pcm onto lt1?
As the tittle says?
I was thinking on trying this myself... Using an ls1 reluctor wheel with an electromotive crank trigger kit or something similar...
Any thoughts?
Any thoughts?
yeah well his title says LS1 PCM on an LT1.... YOu can get a COP setup (Coil on plug) setup but I believe you will have to go to aftermarket engine mgmt... like BS3 or FAST..... if you plug in an LS1 PCM even with a COP setup your car will probably never start.... ever....
Originally Posted by ultra 94 z
I am running a ls1 big stuff 3 ls1 dfi on my lt1 now uses coil packs and even comes with reluctor wheel and cam sensor that drops in distr hole
Not something worth taking on imho but I would love to see someone else try it because if it works out and proves to be beneficial then they could do a write up and save me the leg work and headache. So I say go for it
Originally Posted by The highlander
Can you share some pictures... If you can just get the crank signal working... It can be done.
Sorry dont have pics at the monent and my car is at a secret location working out a few bugs abd getting ready to dyno tune when i get it back I will get some pics also my big stuff 3 came with a brand new ls1 wiring harness a crank sensor and cam sensor and a reluctor ring that bolts to my ati balancer nice setup
