carb. conversion
Even if he is a full blown racer, the fueling of the cylinder is better with injection and it adapts to weather and altitude changes far better than carb. Not to mention it is far easier to tune.
There was a guy here in a Cyclone that was running 10.2-10.3 and switched to fuel injected and is now running high 9s. I would consider him a full blown racer too.
Don't know anyone who has but I have considered the idea. It's actually not that complicated, just time consuming, as are most things on a lt1. There are a few books out that can provide helpful info on the matter. If you are serious about the swap.
I'm willing to bet my left one that it's easier to tune a carb for a weekend car than it is to buy a lap top, buy LT1 edit, Buy datalogging software, buy a wide band, and buy books to tune a FI car. Not taking one side or the other but if his reasons are good I wouldnt knock the thought.
You do realize your pushrod motor is outdated as well correct? I say if it aint broke dont fix it. If youve had good success with a certain setup stick with it. Dont be hatin.
I dont see a reason to drive pushrod cars when thier are DOHC cobras around. I can go all day. The point is youre arguing about old technology but you drive a outdated Camaro with outdated suspension, engine, and body. Youre being a hypocrite.
Originally Posted by aggiez28
the last setup big rick (the worlds fastest LT1) had was a carbed setup.
brook
brook
There are a couple people that have done it around here. One carbed the LT! and the other put an older small block in it (400) It is some work involved cutting the cowl is the roughest part. Getting cut enough to clear and still keep the wipers and all functioning. If anyone has had the typical "LT1" problems I can see why they would want to switch. Nothing gets old "quicker" than not being able to drive your car cause the opti,egr,PCM,....ect....ect...is out. Besides the guy just got on here asking a question and you are making him sound like an idiot, for asking. So next time try to be constructive instead of an A$$.
More than a few guys who went through with this have come back and admitted it was a mistake and those are just the ones man enough to admit it.
As far as the wideband and all that would help the carbed guys too. If you can tune a carbed car you don't need books to tune a injected one. For under $350 you can get a laptop(old 266mhz is plenty and cheap), Tunercat, cable, and Datamaster, that is less than just the carb or manifold/distributor.
The injection is a big part of why we can run 12:1 on pump gas or have a 500fwhp smallblock that is drivable and gets 20mpg.
This like the guys who swear they need a TH400 but they lose a good first gear OD and lockup, making for crappy launches and crappy highway manners all because they wont trust one of the shops proven to be able to build the 4L60E for a 10 second car.
I'd say if you need the extra air to feed your motor, then do it. You can only do so much to a stock lt1/lt4 intake setup. But if you ever outgrow a carb, you can just swap to a larger one. If i had to do the carb swap again, i probably wouldve used an lt1 block splayed for 4 bolt mains, that way i wouldnt have my distributor burried under the windshield. I do still have my wipers and they work fine. I can get to my distributor easily and replace everything, but if i ever had to change my intake manifold i would have to pull the motor. This wont be the way in your case, so you will have some advantages. But if you are stock cubes, i wouldnt even worry about it. If i were to use the lt1 setup on my motor, it would choke it, i would probably lose a decent amount of torque, etc. But then again i have a 383 with a demon carb that demands that air flow. If you do run carb, you will have to use a fuel pressure regulator and replumb your system in the engine bay. But to sum things up, carb and FI both have their ups and downs. For a daily driver i would leave it. But if you ever plan on going big cubes and have a bad *** toy, definitely do it. Hope this helps you make up your mind.
Did you see the 500+RWHP post??? might be worth reeducating yourself on what is possible, and just how well that choke of an LT1 intake can actually work.
People write things off far too quickly a few short years ago 400rwhp with ported stock castings was little more than a dream now there are several shops capable of reliably delivering it.
For those of you that do go through with this the 91-3 b-bodies with the TBI used a large bore distributor hole and the distributor to match in order to facilitate fitment under the cowl. Might go to the boneyard and get one of those distributors and look at having the intake drilled to match. Not sure it would give you enough room but is an idea.
Well the forums dont help when you 5 guys saying the LT1 intake cant handle high horse power then 5 other gyuys saying it can. It's always been confusing to me.
