Jacking The LT1 Up? Tell me if these Pics look right.
Old 06-06-2006, 04:19 PM
hashtagBMW
Speed Density's Avatar
Default Jacking The LT1 Up? Tell me if these Pics look right.
I know this doesnt belong here but i need some advice before i let the jack of and let the stands do the work.
Its at a little notch in the K-Member, the stand seem to fit nicely and it gives me a lot of room to work with.
If its not right tell me were to put them.
Ton.y
Old 06-06-2006, 05:13 PM
slowmofo's Avatar
IMO, that should work if it gives you enough room, hard to tell by pics though
Old 06-06-2006, 05:34 PM
dhdenney's Avatar
I usually put them in the holes of the LCA's.
Old 06-06-2006, 06:19 PM
BlackBirdWs6Zzz's Avatar
what are you doing ?
Old 06-06-2006, 07:18 PM
urbanhunter44's Avatar
i use the front frame rails in the front, and LCA -> Frame mount in the back. I love 4th gens, EXTREMELY easy to rack up on the lift.
Like my nova, it's so light (~2500 lbs) i just grab it at the pinchwelds
Old 06-06-2006, 10:02 PM
hashtagBMW
Engine is coming out, thats what im doing.
Old 06-06-2006, 11:16 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
You don't even know how to jack your car up yet and you wanna pull the motor?
Old 06-07-2006, 12:43 AM
blind527's Avatar
I don't think that was his point. I'm willing to bet he knows how, but was asking if that is another safe place to jack it up from. There is no shame in asking questions. Even professionals learn something new everyday.
Btw...what should I jack my car up by when I put the new LCA's in?
Old 06-07-2006, 01:22 AM
Sgt. Spuds's Avatar
oh oh oh sorry misunderstood
I always jack my rear up by the diff, and put the jackstands on the rear housing.
Old 06-07-2006, 03:46 AM
hashtagBMW
Im going to put jackstands on the rear housing to take out my engine...huh ironic.
Old 06-07-2006, 04:06 AM
the_merv's Avatar
I put the Jackstands on the Rear Axle right next to the Control Arm Brackets, and on the front I put them on the framing that curves in, just inside of the Factory Jack points. I have to jack it up from them points, the car is too low to get the smallest jack I have under it. Depending on how high I have to go with it, I put them on the K member, in where it bolts to the Frame. That is a strong point of the car also.
Old 06-07-2006, 04:08 AM
the_merv's Avatar
Put them on the Framing, or the K member mounts. That is where I put mine when I changed out the Lower Control Arm Bushings. If you ever put your car on a 4-point lift, then put the stands where you would put the Lift Arms.
Old 06-07-2006, 09:50 PM
doug1105's Avatar
Yep-this is what I do.
Old 06-08-2006, 12:31 AM
94z28L's Avatar
im about to put on my new LCA's and am plannin on jackin it up by the rear end then puttin jack stands underneath just like you guys have described too
Old 06-08-2006, 05:24 AM
leadfoot4's Avatar
If you're going to remove the engine, I'd be REALLY CAREFULL where I placed the jack stands. Removing almost 500 lbs. of weight from the front of the car is going to cause the car to shift around as the engine is lifted.
My advice would be to buy a couple 2x10s, and cut them into 12" lenghts. Stack them under the tires, as 4 or 5 "slices" of wood will get the car 8-10" off the ground, and you'll have the stability of the car sitting on its front wheels.
Someone said "Why jack up the back, to pull the engine??" So you can disconnect the transmission, Einstein! I'd use jackstands under the rear axle for that. Don't forget to put something under the panhard bar mount, on the rear axle. This will prevent the axle from rotating, when you disconnect the torque arm from the tranny, assuming you're also taking the tranny out.
Old 06-08-2006, 06:50 AM
the_merv's Avatar
If you have acess to a 4-point lift, use that and drop the engine out from underneath the car. It's alot simpler.
Old 06-08-2006, 06:13 PM
383LT1S10's Avatar
I have 4 pairs of heavy duty 5 ton jackstands that will easily hold any car 18"-20" off the ground. Makes swapping trannys a peice of cake. I always go under the rear diff and on the front of most cars (some not all) I use the frame mount for the front sway bar.
Old 06-08-2006, 07:00 PM
brandboZ28's Avatar
Are you pulling the motor out of the top or dropping it out of the bottom?
Old 06-08-2006, 07:23 PM
slowmofo's Avatar
I think he's going out the top
Old 06-09-2006, 05:32 PM
hashtagBMW
Top, the motor is out. Check out my "Engine Pull Progress Pic" Thread theres some sharty pics of it in there.
Quick Reply: Jacking The LT1 Up? Tell me if these Pics look right.
