Intakelbows.com EFI Conversion?...
Has anyone done this EFI Conversion with the old shcool intake and their elbow? Its very intrigueing. Just wondering the scoop.
That elbow will allow you to use your stock style throttle body (58mm, monoblade...etc). In turn makes the conversion 10 times easier than if you had to get the PTE round elbow and a Accufab 9mm round T-body. I wish this elbow would have been out when I did my conversion. Then I could have kept my monoblade.
Yea..seems like a general question, but what are the advantages of this over the Factory Piece? Just alot more HP potential? Would it really be of any benefit on a mostly stock motor? Or something to wait until a full build-up ?
Originally Posted by Speed Density
After Researching the whole EFI setup, it seem most people only do the conversion with bigger cubes and a big race motor.
Tony.
Tony.
Mine is not a big bad race motor. Well it's big and bad but not for racing at the this point. I wanted to build this motor for the street mainly. To be as my daily driver. We will find out in the next couple of weeks how streetable it will be. Mine should be more streetable than tony's hopefully.
Being hydraulic roller and yanking the linkage off my stock Tb or whatever you call it on the side of the TB. It should have the same opening ratio as stock, and I think that will help out on tuning.
we'll see
we'll see
I have the Offy super-sonic intake for my 425 at www.intakeelbows.com right now being converted for EFI.
I'm building my own intake elbow to use an LT1 throttle body. One question I've had is how much power can a 52 or 58mm throttle body support?
I'm building the engine for 550-600HP and checking the Megasquirt website, they had a calculator for how much power a given throttle body size could support and I thought it was a bit off. According to their calculator, a 58mm throttle body will only support around 360HP??
Any thoughts?
Thanks,
Any thoughts?
Thanks,
i was tinking of doing this set up on my 396CI build but now i am thinking of going bigger like a 408CI....everyone that i have talked to have told me to go with the super vic intake. i am looking into others but mainly going for a long runner set up for the best all around torque.....
