wiring a electric water pump?
Old 06-29-2006, 11:53 PM
Taubr Unit's Avatar
Default wiring a electric water pump?
so when wiring this thing is it just a reg. 12v system or do i need relays n stuff??
Old 06-30-2006, 10:33 AM
Low N Slow's Avatar
They draw enough amperage that you do need to use a relay.
Old 06-30-2006, 12:00 PM
streetwarrior96's Avatar
^^^ ditto
Old 06-30-2006, 01:53 PM
OutlawZ's Avatar
Use a relay.. simple to do with the WP too....
Old 06-30-2006, 02:32 PM
James Montigny's Avatar
6-8A draw, and you want it to come on and shut off automatically.
Use a standard 12V automotive relay and use your fan circuit as a trigger.
Install Guide
http://www.projecttransam.com/projects9.asp (LT1)
http://www.ls1howto.com/index.php?article=26 (LS1 <-- good read even if you are doing an LT1)
Old 06-30-2006, 04:28 PM
UA-Plumber's Avatar
Summit sells a relay kit specifically for electric water pumps. It is like 30 bucks.
Heres the link......
RELAY KIT LINK
Old 06-30-2006, 06:07 PM
seawolf06's Avatar
What I used
Old 06-30-2006, 10:01 PM
Originally Posted by seawolf06
Indicator LEDs are a nice addon, I was thinking of doing that.
I want to hold off a bit and see what happens with the alarm circuits
people are designing. (the ones that tell you "HEY Dumbass, your
pump is drawing too much/too little current and is about to fail!")
Old 08-14-2006, 06:44 PM
TAEnvy's Avatar
Well I dont understand relays so I would run the orange wire form the fise box (fans) into the relay and then what? have it come out the other side of the relay and continue wherever it was going before?
Quick Reply: wiring a electric water pump?
