What can i expect horsepower and torque wise with these mods
Old 06-30-2006, 02:37 AM
gripex's Avatar
Default What can i expect horsepower and torque wise with these mods
Putting a 95 LT1 into my 1988 3/4 ton 4x4.
Heddman 1 5/8 shorties
hypertech Power programmer
GM Hot cam kit with roller rockers(218/228)
Ported stock heads (248 cfm intake)
adjustable regulator set to what ever makes the most power.(36psi?)
Im looking for figures at the crank, as this is a 4x4 and rwhp from a fbody doesnt really apply.
Thanks alot.
Old 06-30-2006, 06:08 AM
94EvilZ28's Avatar
at the fly...I would say around 360-370ish if the LT1s in good shape. Maybe a little more...but why not go for 1 3/4? And I suggest long tubes if its feasible...better performance. Screw the HPP and have your ECM/PCM tuned...its prolly cheaper than the HPP and better gains from it.
Old 06-30-2006, 06:33 AM
LT1BRN's Avatar
Drop 2 things, the Shorty headers (4x4, u wont have clearence issues) and the HPP, put the money some where els.
what ECU/PCM will you be running?
Old 06-30-2006, 01:38 PM
gripex's Avatar
Well the shorties came with the motor.
I have the stock computer and harness.
Ive been told by a few people that this cam is too big for a 4x4 truck application. sure it makes decent hp but the torque kinda sucks. im using engine analyzer 3.0 (dyno simulation software) which also shows crappy torque down low. im thinking a small cam with big lift, or bigger rockers. what do you guys think?
Old 06-30-2006, 02:04 PM
blkchevyz's Avatar
all depends on the gears stall and tires. the hot cam makes decent amount of low end torque, specially if you get a good tune.
Old 06-30-2006, 03:55 PM
hashtagBMW
Speed Density's Avatar
1 billion.
