biggest lt1 cam
Originally Posted by Speed Density
Well your an idiot if you refuse to custom grind.
GM 847
GM 847
i wasted an hour of my life today trying to explain that to a fellow Camaro owner.
Originally Posted by sbcgenII
Does anybody know what the biggest cam would be to fit in a stock motor? I dont care if it funs good or not I just want to say i have the biggest cam evar!!11
Originally Posted by 98vortecbw
ok... whats the biggest streetable cam for a mostly stock lt1? do not want to custom grind
Stop being a cheap *** you want a custom cam, you dont want somthing off the self. A custom cam is the best way to go so listen to what people have to say.
Originally Posted by TwoFast4Lv
man i love reading these posts!
AND to think the search botton is broke again...it is almost as good as the 'easy' button!
What's the deal with a custom cam grind? If a off the shelf cam has the specs to make good power then whats the difference? Does it just sound cool to say you have a CUSTOM cam? I never have understood this..
Because all the duration and all the lift isn't going to make any more power if your heads cant utilize that duration and lift. On stock heads a big cam isn't worth the drivability losses. If you looking for the best results get a heads and cam package that were designed to work together, and a good dyno tune.
I can't wait for this custom cam fad to be over . . .
Mike
