Anybody running over 400 HP with a 10 bolt
Old 08-04-2006, 12:51 PM
ToxicTA's Avatar
Default Anybody running over 400 HP with a 10 bolt
Hello
I am looking for some suggestions to get my 10 bolt to the end of the season. I have already broke it twice since the new motor and have to wait till the winter months to put in a 9 inch. I have seen the aluminum covers that have locking bolts againts the bearing caps are these any help? I have also heard of some people bracing these rear ends. If anybody has any good info please post your information or pics.
Please don't post that you would not stick any more money into the existing 10 bolt I already know that and please don't suggest other manufactures that have bolt ins. I need to get this back together as soon as possible. I have access to the tools needed to reinforce the stocker and already have the new gears (4.56) and the warrantied Auburn Posi Pro.
Thanks
Old 08-04-2006, 12:54 PM
hashtagBMW
Speed Density's Avatar
Get a TA Girdle, they are inexpesive and they are a great strenght adder to a stock 10bolt.
For what its worth, thats my plan to hold me off for a while, my 10 bolt has 142k on it and 4.10s inside and i plan on putting a girdle on it.
Old 08-04-2006, 01:03 PM
titter's Avatar
normally it is wheel hop that tears the 10 bolts apart ... but in your case being a 6 speed is a lot harder on the rear end then a automatic. a girdle will help out a lot, as well as lca's to help suck up any wheel hop. take it easy on the 10 bolt :p no more 5,000 launches haha!
Old 08-04-2006, 03:03 PM
engineermike's Avatar
680 rwhp and rising, stock 10 bolt with 2.73's. I've gone 10.40 at 133 on a 1.52 60', then later on 10.40 at 143 mph with no breakage.
Got a 9" in the works though. . .
Mike
Old 08-04-2006, 04:50 PM
streetwarrior96's Avatar
got mossure axles, Motive 3.73's, Torsen Heavy duty Posi, Master Install kit.
Using 200 shot of NO2
Old 08-04-2006, 04:55 PM
mumu_624's Avatar
I think you Should Just get a MOser 12bolt with 4.11's or 4.10's.......if your gonna Keep 10 bolt you Cant push it to Hard...
Old 08-04-2006, 05:13 PM
look at engineermike with 680 HP... if thats not pushing what is. But yeah you should invest in a 12 or 9" rear
Old 08-04-2006, 05:30 PM
mumu_624's Avatar
he Probly didnt have Traction...
Old 08-04-2006, 05:33 PM
boondiggys's Avatar
ive got a TA cover brand new its designed to preload the differential caps to strengthen the pumpkin...it also adds about a 1/2 pint oil capacity/ keeps rear ends temp. cooler...for you only $125 shipped..let me know
Old 08-04-2006, 07:33 PM
Moderator
JasonShort's Avatar
I was making 480rw NA on a solid roller 396 and I never broke mine. It did have the TA cover though which made me a believer in them. Ran 11.4@126 mph on it.....just go a little easy off the line. That was on hot drag radials too. Never broke, beat on it everyday (powershifting, speed shifting, etc..).
Jason
Old 08-04-2006, 08:20 PM
HBHRacing's Avatar
He was also doing so on the thickest gear set you can run. Change to more teeth of a higher ratio gear and all of that will change.
Old 08-05-2006, 09:47 AM
ToxicTA's Avatar
I was under the impression thta the higher you went in gear ratio the less reliable the gear set would be. Less gear ratio would give you thicker teeth. Or am I to asume that running a higher gear ration like 4.56 would be more reliable.
Old 08-05-2006, 10:19 AM
HBHRacing's Avatar
It's all about tooth contact and load forces. Lower numerical gears have more contact on the teeth which lead to less stress. There is also teh argument that 2.73's will wind out a lot slower then a higher ratio and cause less stress which I guess is true to a point. Also teh fact that it's a 2 serise carrier and not a 3 comes into play as well.
Old 08-05-2006, 07:51 PM
Gun5's Avatar
which carrier is better i assume the 2 is more meat...
Old 08-05-2006, 10:09 PM
titter's Avatar
1.52 60' is plenty of traction. however he has the thickest gear as stated, and is an automatic which takes a lot more of the brunt off the rear end then a 6 speed.
Old 08-05-2006, 10:12 PM
ToxicTA's Avatar
Anybody know what he is running for a gear.
Old 08-06-2006, 12:59 AM
I'm assuming you mean me. I was running a 3.42 when I pulled the 10.40 on a 1.52. Right now, I'm running a GM 2.73 with the turbo. It doesn't pull a great 60' but still got a 10.40, but at 143 mph.
Mike
Old 08-06-2006, 04:03 AM
titter's Avatar
Mike
nice time on a 10 bolt, and that gear!
Old 08-07-2006, 05:27 AM
Louvit's Avatar
I run a 10 bolt with a girdle. My highest launch is 4,000 and i try to slip the clutch a bit. I want to learn to pre load the suspension with my line lock, that should help a bit. I have 373's and an eaton hd carrier. my best 60 is only 1.83. that is killing me. Now I have spray and am a bit scared to launch on it.
Old 08-07-2006, 12:20 PM
Camaro94SS's Avatar
My friends dad has drag raced for about 30 years now and is also a mechanic...when i asekd him about my 10 bolt he said i can typically go low 11s and high 10s with a good lucky 10 bolt....But then again he didnt say it would BREAK...he just said you need to really watch it then
Quick Reply: Anybody running over 400 HP with a 10 bolt
