LT1 cutting out at high rpms
Old 08-08-2006, 05:06 AM
LoStOCeAnZ63's Avatar
Default LT1 cutting out at high rpms
i have a problem with my car when i get around 5,000 rpms the car starts cutting out and it will start making a fast poping sounds out of the mufflers hich means that its miss firing right? so what do you guys think the problem is?
spark plug wire?
Old 08-08-2006, 09:26 AM
slow96z's Avatar
It could be a plug wire, but I'm going to lean more to either the coiol ot the opti. First (and free) make sure your plugs are all in good. I had the #1 almost come out on me and it created a misfire like condition. Arc out the wires and make sure you're getting spark on all 8 and the coil before you change the opti.
Old 08-08-2006, 12:16 PM
95355lt1's Avatar
I had a similar issue with my 94z28, It was a combonation of cocrosion on the inside of the coil wire and coil post corosion, also I found later that the red wire on the harness that atatches to the coil had a break in it, the wire was just kinda mashed together, fixed that and never had anymore problems with ignition
Old 08-09-2006, 04:00 PM
kennyxg's Avatar
Default Misfire
I just went through the same problem. Is the car running ok when your at lower rpms ? if so then the problem is your coil. I just replaced mine and it solved the problem.Bought one at Oriely's for 14 bucks. I had replaced my Opti, plugs, and wires but it turned out to be the coil.
Old 08-09-2006, 06:57 PM
LTSpeed's Avatar
Sometimes I wonder if it's a bad coil that leads to fried optis?
Quick Reply: LT1 cutting out at high rpms
