constant surge??
constant surge??
Ok guys, I have been battling a surging issue for a while now and can not put my finger on it. It is always there open or closed loop. at a descent normal rpm while driving anything under 3k it sjust has a bad surge to it. I have tried and checked about everything i know, anyone with any similiar issues?
I have the same problem, my car is running way lean so I put new O2 sensors in and it seemed to fix my problem for about 2 weeks it just came back last week. If you find an ansewer let me know. I have a 94 ta with LE2 heads, 847 cam, LT's, 30lbs. injectors.
do you have your pcm retuned for those mods?
LALT1 - do you will have your egr valve hooked up? if so rip it off and get it tuned out. or like buffman said, it could be cam surge
Egr is gone, not cam surge as this set up was on a different car with no issues. Acts like a damn vaccum leak but cant find anything anywhere.
my car does the same **** and i've changed injectors and have had 4 dyno tunes from matt at TTP trying to fix the problem, but it won't seem to go away. i'm thinking maybe fuel pressure issues but won't find out till i put the guage on it. will let you know asap.
