OK< I give up
OK< I give up
When I bought this 96 TA, it had an oil leak that took out the opti. the front cover of the engine was coated in oil, so I replaced the opti and the seal. Start her up, she purrs, no leak, go for 3 minute drive, massive leak. OPti seal dry, rest of front cover wet. Proceed with replacing waterpump seal x2, crank seal, manifold seal dry, still same problem. Seems like the crank is slinging oil when I drive it. I watched everything from under the car while it ran after a cleanup for like 10 minutes, nothing. Drive for a few and a mess.
There was no visible groove in the crank snout, but could this be out of spec and leaking past the new seal?
The other 2 openings (opti and waterpump) are dry.
Thanks for any advice.
it could still be anything. It could be the cover seal itself, the manifold gasket, anything. There is just no way that we can tell you. It's something your going to have to investigate and find the source.
Sounds like the timing chain cover filling up with oil. Remove timing chain cover, clean out sludge, change timing chain set while you're at it, reassemble. Happy days are here again.
I'm having the same problem going to put in new opti and seal. also going to put gaskets on timing chain cover, intake, water pump and anything else in that area this weekend... let me no if you figure it out....
I never looked into the timing cover filling up issue though... Interesting....
Originally Posted by Dr. Teeth
Thanks! Do you know if I need to drop the oilpan to get the cover off?
Fel-Pro has a good gasket kit. I used it when I installed my MSD unit.
