is my '94 lt1 internally or externally ballanced?
Old 08-28-2006, 06:46 PM
Taubr Unit's Avatar
Default is my '94 lt1 internally or externally ballanced?
i need to buy a flex plate and my shop needs to know if my car is internal or external ballanced?
Old 08-28-2006, 06:56 PM
cnorton's Avatar
Internally balanced on the front, externally balanced at the rear. LT1 has a specific flexplate.
Old 08-28-2006, 08:21 PM
Taubr Unit's Avatar
yes, he has a lt1 specific flex plate but 1 is for eaither or and BOTH for lt1. so how do i know what i have. unless the 1 is for a rebuild engine and you change the ballancing, i dunno. but he shows 2 for lt1's. ones internal and ones external.
Old 08-28-2006, 09:41 PM
FlamingChicken's Avatar
just thinking out loud but if the lt1 is externally balanced at the rear i would assume the flexplate should be for external. I think the internal flexplate would be if you had a completely internal balanced engine, like if you had it rebuilt.
Old 08-28-2006, 10:14 PM
91Z28's Avatar
The only small block to be externally balanced was the 400. When they switched to the 1 piece rear main seal in 87 one of the weights was moved to the flexplate/flywheel, but the engine is still internally balanced. Someone led me to believe the same thing about the "internal front/external rear" myth and it cost me a 484$ flywheel.
Old 08-28-2006, 11:46 PM
Dragframe's Avatar
internaly balenced... jsut have the roating assembly balenced... easy enough. Have someone else rebuild that thing
Old 08-28-2006, 11:59 PM
Taubr Unit's Avatar
im not having nothing ballanced or rebuilt. All i want is a flex plate to buy. Easy enough.
Old 08-29-2006, 07:02 AM
daniel6718's Avatar
go buy a new stock flywheel..it will work...after 3 months of building a car and trying to find a motor vibration...i pulled the tranny and the flywheel i bought was zero balanced...i simply bought a new one from a guy i kno that buys in bulk from gm...cost 135 for a brand new 6 speed flywheel from gm...put it on smoothe as glasss.
Old 08-29-2006, 07:43 AM
paul67's Avatar
What about removing the old flexi and seeing if theres any weights or holes drilled , if not get it balanced checked to see how well its balanced if its perfect then the flexi's balanced, if not get new plate and get it balanced to match the old flexi.
Old 08-29-2006, 09:15 AM
Taubr Unit's Avatar
i cant use a stocker, i need a SFI one. Im prob. gettin the TCI one.
Old 08-30-2006, 02:53 PM
TWS
TWS's Avatar
I did. I think it's a good choice.
Attached Thumbnails is my '94 lt1 internally or externally ballanced?-lt4-ready-rear-small.jpg
Quick Reply: is my '94 lt1 internally or externally ballanced?
