Either of these worth it?
Should I get one of these CAI kits or are they not much improvement over stock air box? I see the good ones are alot more $$$$.
http://cgi.ebay.com/ebaymotors/K-N-9...23320659QQrdZ1
http://cgi.ebay.com/ebaymotors/93-94...24087063QQrdZ1
http://cgi.ebay.com/ebaymotors/Z28-F...26629681QQrdZ1
the intakes in the first and third link will do nothing but suck up hot engine air. the second link looks like a better setup, but seems to have nothing to block the hot air from getting down near the filter element. i would save up and buy a slp, moroso, k&n, etc....
You get what you pay for.
If someone says a kit like that is fine, thats because they probably bought a similar one, or cobbed one themselves and want to justify it.
Bottom line is, REAL Cold Air Kits are 2X bigger than the stocker, and they relocate the filter to alot better of a position below where the old airbox used to be. Plus they are designed and tested for maximum airflow.
Originally Posted by 96lt1m6
the big thing is LPE,SLP,K&N and MOROSO did r & d work to provide the best they could to supply the public of course we pay for that!my opinion is to spend the cash on a proven product.
Those intake are also very resonable in price
what he said.
as a mattr of fact, i would custom make one out of PVC rather than going with one of those.
Originally Posted by LT1BRN
what he said.
Originally Posted by OnA Fan
I have been thinking about what you wrote. I currently have the front bumper cover off the car for repaint and was looking at all the space in there. I also remember seeing a write up on a 3rd gen TPI with a home made PVC setup that was plumbed to the front of the car. Would it make sence to try and route some 3" PVC from the stock air box to the front of the car and open up the block-off plates for the "ram air" effect, or just delete the airbox and go with 2 cone filters, or will the extra pipe restrict the airflow and make the setup useless?
I still recomend that u save up adn go with a Branded one (think K&N, Moroso, SLP, LPE)
Most of the name brand ones I've seen are for 94 and up.
MAF wont be a problem since 93s don't have them.
I was thinking not only going as low as could, but actually getting the filter out of the engine compartment and forward, and opening up the block off plaes to feed it fresh air.
