how accurate are the gauges in 97 camaro's?
Finishing up my z and wanted to know how accurate the factory gauges are if there are any I should buy. I'm putting a 383 with the le2 head & cam with all the supporting mods. It's also a 6 speed if that matters any. I've spent alot of money and want to protect it any help is greatly apperciated.
I heard that on the ls1 cars the coolant temp gauges aren't accurate. And I'm pretty sure the tachs aren't accurate because my shift light comes on at 6400 in my 00 ss but the tach doesn't always show that. I'm not a fan of gauges being every where when their not needed, but I do want to protect my investment. Thanks for the help.
BRETTINATOR thanks for the reply and I like the camaro. Hoping mine will put 430+ to the wheels. Kinda wish I had went a little more aggressive on the heads and cam but oh well it should still be fun.
That's all I have is a light. Since it's wired to the tach signal anyway, you'll see the light instead of the needle anyway. 99 times out of 100 you probably wouldn't even notice the needle being behind if you have the light.
Originally Posted by speed_demon24
Comparing to my scanmaster, the tach is dead on at upper RPM's (couple hundred high at idle), speedo is within 1mph, volts is fine, but the temp gauge is way off. At the 210 mark on the guage my coolant temp sensor reads over 230 degrees.
