1/8 mile times
1/8 mile times
what time should i be running with my stock 94 formula in the 1/8 of a mile. what the best time you have ever seen anyone run with one with stock street tires
by best stock pass on street tires was 8.9... but it was winter time also.. and with little mods still on street tires the best pass was 8.69... i havent been back in a long while.. and i have added alot of things since then... so im curious to see what it will do...
I ran 9.6 in my mostly stock cadillac. It had an intake(home made, and no heat sheilds) a catback, and new valvesprings. A calculator I used said it had 273 hp. so take away 700lbs. also had airlifts to help with the launch. so i would say that in stock form with a slightly choked(more so than later years) z28, you should see around 9.3ish. I used this to calculate my hp, but it said I should run a(1/4 mile) 14.7 at the 92 mph it ran and weight. http://www.tciauto.com/tech_info/calculators.htm when I really ran 15.0 all night.
