Low Coolant Light
Old 10-31-2006, 01:55 PM
1BAD01TA's Avatar
Default Low Coolant Light
Is There A Way To Bypass The Low Coolant Light On A 94 Z28,thanks
Old 10-31-2006, 02:52 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
^ he doesn't know what hes talking about..
Unplug the sensor, no more light.
Old 10-31-2006, 02:57 PM
Hot94Z28's Avatar
Thats what I did it was like that when I bought the car I have had it unpluged since I have bought the car no problems
Old 10-31-2006, 03:04 PM
1BAD01TA's Avatar
Thanks Guys Unpluging It Works, Thanks A Million
Old 10-31-2006, 03:10 PM
camar0corey's Avatar
Where is it located? Mine randomly comes on and off.
I take it if I want to replace it I should do it quickly so I don't get showered in coolant?
Old 10-31-2006, 03:17 PM
Hot94Z28's Avatar
Its on the side right under the rad cap just unplug it just dont forget to check your fluid since the light wont come on even if it is low
Old 10-31-2006, 03:20 PM
Bawls's Avatar
about 4" below you radiator cap.
Old 10-31-2006, 03:21 PM
Sgt. Spuds's Avatar
its on the side of the radiator, you have to remove the battery to gain access to it, unless you have girly hands I suppose
Old 10-31-2006, 04:06 PM
Hot94Z28's Avatar
I did it when I had my car jaked up poped it out from under the car
Old 11-02-2006, 01:04 AM
redhot lt-1's Avatar
my light is on to i always thought if the computor doesn`t read the sensor it would come on anyway
Old 11-02-2006, 01:57 PM
Bawls's Avatar
For some sensors yes, but not this one.
Quick Reply: Low Coolant Light
