Whos Opti-spark Should I Go With
Old 01-02-2007, 04:25 PM
madmatt97's Avatar
Default Whos Opti-spark Should I Go With
IM looking to get a new optispark I keep breaking apart the rotor in the AC Delco ones that have been put on. Whos distributor should I go with Accel or MSD?
Old 01-02-2007, 04:28 PM
1994Z28Lt1's Avatar
how many rpms are you running? im not sure if the accel can handle a lot of rpms but i do know the dynaspark can handle up to 6800 reliably i am sure the msd is similar so i would pick between either of them
i have the dynaspark and it hasn't given me any problems in 30,000 miles so far
Old 01-02-2007, 04:37 PM
lt197formula's Avatar
Another vote for the dynaspark. I have one with 9k miles and consistently run it up to 6800 with no problems.
Old 01-02-2007, 05:47 PM
madmatt97's Avatar
well my revlimiter is set at 6800rpm but i run about 6600rpm
Old 01-02-2007, 05:50 PM
madmatt97's Avatar
were can i buy the dynaspark for a cheaper price?
Old 01-02-2007, 06:07 PM
96capricemgr's Avatar
Put an MDS cap and rotor on the stock opti.
Old 01-02-2007, 06:29 PM
I bought mine from Thunder Racing (they are a sponser--->) on one of their past sales so I got a good deal.
Old 01-02-2007, 06:33 PM
freshmanit's Avatar
I like my MSD.. just wish it came with a marking for timing. err Would have saved a lot of time.
Old 01-02-2007, 07:18 PM
camar0corey's Avatar
The MSD is rated to 10k rpm. Been very happy with my MSD.
I've heard the Accel is just a rebadged Ac Delco unit or something like that, so probably not the best idea, if you destroy factory optis.
Old 01-04-2007, 11:13 PM
madmatt97's Avatar
would this work or would it just fall apart in the next 500 miles again like the stock opti did
Old 01-05-2007, 02:46 AM
Gun5's Avatar
my stock opti with msd cap and rotor FAILED @ 700 miles.. on a MSD Pro Billet now only 100 miles on it so far
Old 01-05-2007, 08:25 AM
Yes get the whole MSD unit. Don't do just the cap and rotor, I think by trying to bandage my stock opti with the cap and rotor it lasted a whole 6 months, 5 of which the car didn't get driven much.
Old 01-05-2007, 09:12 AM
madmatt97's Avatar
ok thanks guys
Old 01-05-2007, 09:19 AM
madmatt97's Avatar
do I need anything to go with the MSD opti like the MSD blaster coil or will the stock coil work just fine?
Old 01-05-2007, 03:14 PM
stock coil is fine
Old 01-05-2007, 08:19 PM
Leedogg's Avatar
Got about 15 1/8th mile passes and about 1000 hard miles on my MSD Pro Billit so far- works flawlesly so far.
Old 01-05-2007, 09:57 PM
madmatt97's Avatar
cool. I just bought the MSD today so i hope it works well for me thank guys for all ur help and advice
Old 01-05-2007, 10:33 PM
qqwqeqwrqwqtq's Avatar
I just use a stock GM opti with riveted rotor contact. (drill out plastic rivets and install aluminum rivets). Mine is going on 2+ years like this and I've seen 7,650 rpm on the datalogs.
Old 01-06-2007, 04:05 AM
B4CZR2's Avatar
WOW! I just looked at the pics of your car, and wow! That is awesome
Your car is beautiful! Great job! I wish I had the time and the funds to do that with my car!
Old 01-06-2007, 10:48 AM
One thing you want to check with the MSD though, make sure the rotor screw is tight, you have to pull the cap off anyway to install the gasket, so check to make sure.
thats the only issue I have heard of MSD opti's so far, a few people have had the rotor come loose, fall off. And thats only happened to a few people, just double check.
Quick Reply: Whos Opti-spark Should I Go With
