94 lt1 drops out under heavy throttle
runnin vortec alum. intake elbow. all else is sealed tight and has been for about a yr. problem just started. it sux! rides fine till i punch it, then everything just "drops out".
yea i work at a gm dealership and i've heard things about the coil as well. other than that, plugs and wires are pretty new and good. no computer mods yet.
I have had the opti, plugs and wires replaced. I hope mine is just tunning, but we will see. Car runs fine other wise.. and seems to hold well on the street.
-bryan
-bryan
Mine did the same thing but i found mine to be the fuel pump. I got spark and all but the fuel lines weren't priming. it would just turn over and over and over. My brother ended up using my opti on his car so I knew it wasn't that.
yea i did fuel pressure tests multiple times and it only surged when it hit the point of "cutting out on me." my msd coil on there now has been on it for about 4 yrs now, hopefully its just reached its life expectancy. now i'm switching to the hypertech coil : 53,000 volts instead of the 45,000 (msd).
Just wondering but when you said no codes showed up on the tech 2 at work??? Don't you mean on the tech1? since a 94 is OBD 1, not OBD 2. Sounds like opti though.
I am guessing it's the Opti...I had the same problem with my 94 z28.
It drove perfect, and then when you wanted to open her up and steped it down, it started hesitating and fell on its face etc..
