WATER PUMPS for dummies
This might be easier than I'm making it, but the reverse flow
thing has me confused! I am using a '93-'96 vette pump, so
there are only two outlets, upper points to the DR side, lower
points to the PASS side. I am using a down-flow radiator in a
'57 Chevy. How should these hoses be routed?
Thanks!
Jeff
Thanks!
Jeff
I'm not sure of this .....but on my LT1 engine the Thermostat housing upper outlet goes to the lower spot on radiator. The other large outlet lower goes to the top radiator outlet.
http://cgi.ebay.com/ebaymotors/corve...QQcmdZViewItem
Should hold true as long as this pic is upside down. If it is actually mounted like this, Im with you, I have no idea.
