will this cam work?
will this cam work?
a guy i work with was building a small block chevy back in the mid 80`s but never finished.he still has the cam 1.6 roller rockers and the springs all brand new never run.can i run the cam,rockers and springs?
the cam is a solid cam and heres the specks
intake 294 deg lift .533
exhaust 302 deg .555
intake duration 258 deg @ .050
exhaust duration 262 deg @ .050
LSA 105 deg
intake lobe lift .353
exhaust lobe lift .367
what do you guys think?
LSA 105 deg
Internet Mechanic
You would have to check piston to valve clearance, the lift with a 1.6 roller rocker will eb under .600" lift but how long its hanging down there will be an issue.
A Big thing that I dont see is cyl heads, and what rpm the power band is going to be, on stock bottom end I wouldnt spin it past 6k and expect it to last. Most solid rollers like the rpm and LT1's shut down before 7k.
Not saying you shouldnt do it, but there are alot of solid roller grinds out there that can suit your needs, dont get something just because its there.
It WILL not work neither physically or worth the effort if it would fit. #1 the cam face and bolt pattern is different and you can't use a LT1 or Cloyes 86-up on it. #2 Wheres he gonna bolt his opti since the alignment shaft cant go into the cam?
The way I read it, he was saying that it was a solid cam, not a solid roller. I don't think you can make a solid flat tappet lifter cam even work in a late model block. I thought that I read somewhere the oiling holes are located in different spots.
