lt1 ?'s
lt1 ?'s
Ive been thinking about buying either a cam and headers or a cam and a stall, i dont have enough money to buy a stall and headers, so which one do you think i would get the most performance out of thanks guys
People think cam swaps are cheap but by the time you get springs gaskets and fluids rockers studs, guideplate pushrods, they are not so cheap.
I did a cam early on and frankly it really needed both stall and headers and mine was a very mild 208/221 cam.
Do the stall and headers first.
Cam will at least give the car an awesome sound. Stall will set you back in the seat when you floor it. You must consider costs involved in doing a cam or stall. A cam will determined your stall speed. If I was you, I would do headers first, then camshaft, and according to the cam I would choose a stall converter.
Yea stall/headers should give you around .7-.8 off you ET. Thats assuming you have tires to handle the stall...
The parts for a cam swap will set you back almost 1k alone...
