Connecting Rods
Connecting Rods
I just dropped my block of to get machined and assembled but I am wondering what rods to use. I was thinking of going with Scat forged 6" I beams. Has anyone ever had any experience with them they seem to be better and lighter then eagle and i don't really want to run H-beam.
You should have Pink rods in yours, and they should handle around 450 from what I understand.
Make sure to get everything balanced. You won't regret spending the extra few bucks.
Yes every thing is getting balanced I just wanted to go with the forged rods for extra insurance in Summit it says they are rated to 750hp so they should do the job.
Well I see why he doesn't want to run the h-beams. He wants to make his rotating assembly as light as possible. Since he won't be using a power adder he doesn't need h-beams, using I-beams will save you a considerable amount of weight. (Rotating Mass) I guess that's why he's using I-beams.
The Scat I-beams have been as strong as the H-beams. Have used them in a few boat engines and going into my LTx right now. Just make sure it is the 7/16 bolt and your all set. The other good thing is the smaller profile is nice for strokers. Scat did a great job on making a very good rod for a GREAT price.
Thats just my 2cents.
Thx also for the input guys
My current shortblock has pinks in it and I was frankly disappointed to find them, they are holding up but I would not reuse them on a build. Probably cost $160 to rebuild tham and they are still straight out of 1970.
IMO a 6" Scat rod is a good idea, lighter piston due to the 6" rod makes life easier on the rods too.
Originally Posted by 96capricemgr
400rwhp is well over 450crank HP.
A true pink rod that has gone through shot peen, magnifluxed, resized, and arp bolts will handle a crap loud of power and i have used in many good horsepowered cars... i never reuse a stock lt1 rod or a piston on a rebuild..
IMO the rod angle, dwell etc. are all overrated at least for our level of play. The light piston is the real tangible benifit.
