Nitrous questions?????????
I'm wanting to put a 100 shot wet, on my 95 LT1 auto, pcmforless tune, cold air, 373. What am i gonna need in addition to the kit its self? such as how to reduce timing? Im wanting the motor to last as long as possible.
Along with a bare bone wet kit, you're going to need a window switch, one heat range colder plugs, a fuel pressure safety switch, some way to pull timing, and a bottle warmer.
To pull timing you've got two options -- get it done through a tune, but you'll lose a little bit on motor. Or purchase an aftermarket ignition system that will pull timing. A MSD Digital 6 and a Mallory 685 will both do the same thing as far as pulling timing for when a nitrous system is activated.
