help what temp are cooking fans to turn on
my car is at the shop right now it just got new head gaskets lt4 hotcam kit 160 degree thermostat etc. put on the whole reason i took it in was because i blew my head gaskets from my cooling fans not coming on. what temp are they supposed to turn on the guy at the shop said there was nothing wrong with them they just come on around 260 degrees. isnt that a little high?
Fan Mode
Temperature A/C Pressure
Primary (RH) Fan ON 109 C 229 F 189 psi
Primary (RH) Fan OFF 105 C 221 F 150 psi
Secondary (LH) Fan ON 112 C 234 F 240 psi
Secondary (LH) Fan OFF 108 C 227 F 210 psi
Additionally, the PCM will turn off the
fans at higher vehicle speeds (above 48 MPH I believe) since running fans can
actually impede airflow through the radiator at high speed. Each fan also has a
minimum running time. Once activated, the primary fan will run for a minimum of
50 seconds, and the secondary fan for a minimum of 26 seconds. Finally, certain
Diagnostic Trouble Codes (DTCs) may cause the PCM to turn on one or both fans.
i just got it today it seems to stay around the quarter mark i live in texas too and i don't want all the money i just spent to go to waste because it overheated again
