Gm847 Tune
Old 03-23-2007, 08:24 PM
94'BLKBRD's Avatar
Default Gm847 Tune
Im picking up my car tommorrow after getting the gm847 cam done.....So now I need a TUNE! so what tune should I do? dyno tune,mail-order tune?what do I need to do a mail order tune?and where can I buy a mail order tune?
thanks
Old 03-23-2007, 08:43 PM
plaf713's Avatar
with your mods being not to serious i would go with a mail in tune, but if you want a really good tune then go with a dynotune, it all depends on how much you want to pay
Old 03-23-2007, 09:11 PM
94'BLKBRD's Avatar
how much is a mail in tune???which is the best mail in tune I can get and how does a mail in tune work?
Old 03-23-2007, 10:38 PM
94'BLKBRD's Avatar
im also putting bigger injectors in and i was wondering if these would fit on my lt1
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Old 03-23-2007, 11:36 PM
Schweet97Z's Avatar
With mail order tunes, you just have to becareful the tune isnt so rich to where u wash the rings. I think i might be running into that problem since i did the H/C because i checked the oil the other day, and it looks real clean, but it smells alittle gassy. Im going to get it dyno tuned by Bryan Herter at PCMForLess this comming Thursday. So my vote is a dyno tune.
Old 03-23-2007, 11:39 PM
94'BLKBRD's Avatar
right now my mind is on a mail order tune from pcmforless......but im waiting to get some bigger injectors
Old 03-24-2007, 07:19 AM
Schweet97Z's Avatar
yea there is nothing wrong with a mail order tune, just keep and eye on your oil. you dont want to ruin ur bearings.
Old 03-24-2007, 08:09 AM
plaf713's Avatar
36 lb injectors may be to big for what your doing, i would go with 30 lb injectors, your better off
Old 03-24-2007, 12:52 PM
formula355LT1's Avatar
i think a dyno tune would be your best bet
Old 03-24-2007, 06:25 PM
94'BLKBRD's Avatar
so how does the pcmforless mail tune work?So i just send them my computer/pcm they tune it , I get it back and just plug it back in?
Old 03-24-2007, 07:00 PM
SmokedOutZ28's Avatar
I was running 38lb injectors when i had my 847 cam, you can never go to big on the fuel side of things it can easily be tuned for them and when you run the bigger injectors it allows for room to grow.
I also had a tune from Madz28 he did a awsome job over the so called "Dyno tune" I recieved from a speed shop!!
Old 03-24-2007, 08:30 PM
94'BLKBRD's Avatar
could I use these fuel injectors on my car?
http://cgi.ebay.com/ebaymotors/30-lb...QQcmdZViewItem
Old 03-26-2007, 01:00 AM
94'BLKBRD's Avatar
bump***
Quick Reply: Gm847 Tune
