forget lt1 vs. mustang whats it take to hang with a M3?
Old 05-13-2007, 02:18 PM
littlebird's Avatar
Default forget lt1 vs. mustang whats it take to hang with a M3?
a few months before i got my 94 lt1 in august, i went for a beat run in a BMW M3. it was a straight 6 and it was sick! we could snap 2 doughnuts before you could blink and the accel was just awesome. I am not sure what it would take to match or beat the performance and stay a dd. maybe not as much as i think or maybe its serious cash. my car is basically stock it is a4 w/ 2.73, I do have a cone filter and bilstien shocks. I want 3.73 this summer maybe and a magnaflow catback. headers over the winter hopefully. i have 160k miles on my motor and it still pulls hard. that ride in the M3 is what made me pull the trigger on a cheap go fast car.
Old 05-13-2007, 02:20 PM
Gun5's Avatar
intake, exhaust some 3.73's.. maybe stall it?? some decent tires
Old 05-13-2007, 02:21 PM
topgunbar0's Avatar
what year m3?
Old 05-13-2007, 02:23 PM
Mojave's Avatar
E36 M3's aren't very quick (in a straight line) as they only have ~240 CHP.
E46 is another story, 330 CHP.
Old 05-13-2007, 02:38 PM
LT1
LT1's Avatar
rear gears, good tires, LT headers, CAI, 1.6rr, ported heads, port matched intake, custom cam grind, ignition, adjustable fuel pressure regulator, dyno tune.
with that you should beat him easly.
Old 05-13-2007, 02:41 PM
Mattybz28's Avatar
Buddy has an E36 M3 that I've put a hurtin on a few times. I think his quickest with exhaust and a shifter was a low 9 in the 1/8th.
littlebird's Avatar
i cant remember what year the m3 was, i want to say 2002-2004 and i do remember himsaying it had like 330 hp i6
Old 05-13-2007, 03:00 PM
Formula350's Avatar
CHP? >_>
Your gears are killing your poor car. Get no less than 3.42, but those 3.73 should be fun. Remember to get a 3.23+ carrier when you switch, yours won't work. Get some 26# (or 28# if they don't come in 26) Ford SVO injectors, 52mm TB (Bypassed of course), highflow cat + magnaflow or loudmouth, LT4 KM, the LT's, and if you want to the 1.6 RRs wouldn't hurt. After all that get a good tune with improved tranny line pressure and I think you'll be on par with him. If you get a stall, I wouldn't get anything more than 2000-2200.
Old 05-13-2007, 03:04 PM
F8L LT1 Z28's Avatar
My buddy has a 03 M3 I put like 5 cars on him with mid headers, K&N CAI, SLP LM his car is slow, but other M3's I don't know. there could be some fast ones I don't know about. GOOD LUCK
Old 05-13-2007, 03:30 PM
396D1SS's Avatar
The SS in my sig waxes my buddys new m3 pretty good. So if you get a small bumpstick and headers you should be ok
Old 05-13-2007, 03:36 PM
Revelation Z28's Avatar
CHP= Crank Horsepower.
Old 05-13-2007, 03:47 PM
vin1382's Avatar
e46 m3(330 hp one) can run high 12's stock and trap 106-107, so you will need at least all bolt ons + a cam to consistently beat him. to get close you will need a bigger stall converter, sticky tires, 3.42 or 3.73 gears, headers/cat back and cold air intake and probably a tune. that will get you in the ball park.
Old 05-13-2007, 04:11 PM
396D1SS's Avatar
you will not need all the bolt ons and a cam to beat a stock m3
with 352rwhp from my ls1 ss I can beat them pretty damn good, and a good all bolt on cam lt1 should beat my ls1
When my LT1 car was stock it was trapping 102, with headers,catback and a CAI I was trapping 107
Old 05-13-2007, 04:14 PM
germeezy1's Avatar
They can run high 12's but usually run mid to low 13's...105-106 mph or so.
Stall, 3.73's, good tires, CAI, exhaust and a good tune should be a nice start.
Old 05-13-2007, 04:36 PM
Zralou's Avatar
I had a M3 run me a few weeks back on the way to work. We were both rolling around 70 mph when we got on it, pretty much nose to nose, thankfully he shut down, cause of traffic up front, just as my speed limiter kicked in and killed the motor.
My car is completely stock other than 160* stat and TB bypass, leaking exhaust manifold, noisey lifter and BADLY in need of a tune up.
Sara Lou
Old 05-13-2007, 04:42 PM
Puck's Avatar
Originally Posted by Formula350
CHP? >_>
Stock stall is 1800, I would not go lower then 2800. Bolt on lt1s love 3000-3200 stalls.
For the M3 its not as much as you would think. Full bolt-ons, tune, suspension, and some drs and you will have him if he is stock. No need for ported heads or cam.
Old 05-13-2007, 04:44 PM
kyle91z28's Avatar
What you need is NAWWWZZZ!!!111!!1!one
Old 05-13-2007, 04:56 PM
germeezy1's Avatar
But make sure not to blow the bolts on your intake
Old 05-13-2007, 04:59 PM
Old 05-13-2007, 06:12 PM
burnzilla's Avatar
I beat a late 90's M3 from a stoplight once.
Both had good launches and by 90 had about 3-4 cars on him.
They have the 240hp 3.2... strong little car.
Quick Reply: forget lt1 vs. mustang whats it take to hang with a M3?
