LT1 nitrous gains?
LT1 nitrous gains?
I have a 95 ta A4 with 3.73's, LT'S,ORY,Magnaflow catback, Madz28 tuning, Moroso CAI, SFC'S, TB bypass,tr6's, Msd plug wires and dr's. I run 8.5 - 8-7 1/8 times in this nasty Florida panhandle humidity and heat.( 90 Degree air temperature with 90 to 95% humidity.) I am about to put on a Dynotune wet kit using the 100 shot and was wondering if anyone thinks it is possible for me to break into the 7's with this set up? Does anyone else have a similar set up (bolt ons plus 100 wet shot or anything close to it) and what 1/8 and 1/4 times are you running. Just curious because I would like to know before I go to the track what times to be looking for when I get the kit on.
I have similar mods and ran it with a 100 shot. My mph increased from 103-4 to 116-117 in the 1/4. My time with similar bad launches went from 13.5ish to 12.7, and that was going sideways in 1st when it kicked in at 3k rpm
383 Motor Pass (AFR - 12.8)
60' - 1.80
660' - 7.70 @ 93.5
1/4 - 12.00 @ 117.5 - 4th gear on limiter at 6800 RPM
383 150 Shot @ 900PSI (~120 whp) (AFR - 11.5)
60' - 1.75 *short shifted 1st due to traction loss after N20 hit at 3000
660' - 7.50 @ 97.8
1/4 - 11.47 @ 124 - shifted into 5th
Mods: 383, 10.4:1, AFR 190s, LTs, 232 240 .578 .598 112, 4.10s, MT DRs, McLeod Twin, NX MAF
Stock TB, Unported LT1 Intake, Full Weight 3550Lbs, 6spd
60' - 1.80
660' - 7.70 @ 93.5
660' - 7.50 @ 97.8
