what times?
what times?
What times could you expect out of a stock 94 Firebird formula, that runs like new... it was babied....
Things you could count as mods are TB bypass, Intake, and no muffler...
The track around here has a Elevation of 850'.....
My rear end gears are 2.73's and its an A4 automatic.... Stock weight....
As for as the driver mod :eye: Ive been driving manual for the last couple years, but I do know for the automatic that you just stall it up to 1400 or w/e it is for a stock converter and then slam the gas and let the car shift..... My car shifts perfect.....
I got a 13.7 with what you have minus the TB bypass. I didn't stall it up because I would spin, but dead hooked just punching it. So if you can get no slippage, maybe you can get around 13.7. Then again, a 13.7 with basically intake only isn't that common.
Surprised me too
what was the mileage of the car at the time?
EDIT: the elevation of Fairfax is 447..... if that is actually where the track is, but that may have sumn to do with it....
Their website says 20ft above sea level. My car had 53K miles on it at the time.
Well damn that must be nice then....
Ill go ahead and guess that ill run a low 14 then.... just gotta make it to the track now....
Well guess what. Thousands of dollars later, I'm currently running a 13.6 from the same track . Should of got an ls1 a long time ago!
