Another cam question but differant
I have a 95 fleetwood I have deleted my air pump and I am going to upgrade my valve springs. My car is getting a full frame reinforcement, and hydraulic setup so its going to be real heavy, I would like to get a mild cam while the engine is out, any suggestions what one to get for a heavy *** fleetwood? Thanks
the majority of the people here will point you in the direction of the crane 227 grind which is 210 intake 224 exhaust or a lingenfelter grind 211/ 219 both cams increase low end power and work well with heavier cars
Speed Inc (sponsor on here) sells a "Cadillac Cam" but they don't say what the specs are. It is a comp grind. Here's a link.
http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
