LT4 Heads!!!
Old 08-12-2007, 06:21 PM
Z28Camaro30Ann's Avatar
Default LT4 Heads!!!
I have a 97 Z28 Camaro LT1 all stock. If I wanted to add aluminum LT4 heads to her, what else would I need to change???
Old 08-12-2007, 07:02 PM
nomoneyz's Avatar
You need the lt4 intake. It is not in production through gm anymore but edelbrock makes them now. I'm sure there are better options than those heads, I do not have experience with them though.
Old 08-12-2007, 07:05 PM
ckyconan2003's Avatar
i have the lt4 intake and heads, i got lucky and found a wrecked vette at a junkyard. i wouldnt spend more than 200-300 bucks for the heads n intake.
Old 08-12-2007, 07:07 PM
C5042081's Avatar
i seen a few new LT4 heads and intake go close to 2 grand on ebay
Old 08-12-2007, 07:12 PM
i got lucky and found mine cheap off a totalled vette.
Old 08-12-2007, 09:12 PM
96capricemgr's Avatar
Especially with stock or near stock displacement you will be better off with ported stock heads than LT4s.
Here is where people will get pissy. From what I have seen even on a stroker most people are best served by ported stock castings over LT4s even ported. The LT4 intake is no upgrade either, internally it is the same as the later LT1 intakes it just has more material above the port to seal the taller LT4 head ports, the intake does not come close to matching them though.
Old 08-13-2007, 12:09 AM
socal's Avatar
i run an lt4 w lt4 hotcam kit in my TA for 50k now 320hp at the wheels through a 4l60e and 342's stock tune
my recomendation buy some cores off ebay and spend 2500 to get them ported insted of the lt4 kit
this is who i get my stuff done by, highly recomend them there building my 396 w stage3 lt1 heads
http://gtp-racing.com/
Old 08-13-2007, 12:41 AM
streetwarrior96's Avatar
best bang for the buck..stock castings
Old 08-13-2007, 12:48 AM
the_merv's Avatar
Just a comparison to back everyone else..I had a LT1/LT4 Hotcam Kit with Stock Heads, just Milled and Port-Matched, and it put 335/335 to the ground through a slipping 4L60E.
Old 08-13-2007, 01:31 AM
In-Zane Moderator
ZONES89RS's Avatar
Port the stockers, err find the good castings and get nastier with them.
Old 08-13-2007, 03:28 AM
Right on..so get the stockers ported out and roll with those...got it. Next question...The stocks on my 97 LT1, aluminum or iron??? if Iron, what difference would aluminum make?
Old 08-13-2007, 03:34 AM
the_merv's Avatar
You mean the Heads..go with Aluminum. Iron ones are not setup the same as the Aluminum for the LT1.
Old 08-13-2007, 03:37 AM
In-Zane Moderator
ZONES89RS's Avatar
Your stockers are aluminum, only the caprice and road masters had the iron heads.
Old 08-13-2007, 03:39 AM
Right on, I'll be getting the stock heads ported and all, thanks a lot guys!
Old 08-13-2007, 11:33 AM
speed_demon24's Avatar
If your car is stock you will need all the supporting boltons before you even think about a h/c setup.
Old 08-13-2007, 04:50 PM
396D1SS's Avatar
If you can get them cheap i would go lt4's mod for mod a lt4 head will always outflow a lt1 head at any lift. Being they have identical port work. A good shop can get 300cfm out of LT4's. That and the 58cc with also bump the compression up a tad and make more power
Old 08-14-2007, 08:45 AM
Some of us understand that flow or dyno numbers do not necessarily equal performance. Apparently you have not yet learned that leason.
Old 08-14-2007, 03:51 PM
rob97ss's Avatar
96capricemgr..I follow alot of your post cause you are very informative,but please explain what the lt-4 head is for then?
Old 08-14-2007, 07:25 PM
Well the theory is more as cast performance and to some degree that is the case if you rev high enough.
One of the "Stock Eliminator" guys here says that as cast for as cast he gained a tenth. Now keep in mind Stock Eliminator is cars with as cast intakes and heads and stock TBs running deep in the 10s and shifting higher than our pcm will support.
When you start comparing cars with ported LT4s vs. properly ported LT1s though I fail to see an advantage, not even on a stroker.
I know people will talk about port volume and such and yes for a bigger engine or one revving very high port volume is something to be considered, I just think if you pay attention to performance numbers you will see adequate port volume is smaller than most would have you believe.
A couple months back I think it was GMHTP had an article on the EFI shootout and there were two LTx cars listed with details, a LOT of similarities between the cars, most notable differences were one had worked LT4 heads and several points more compression then the other with AI 200cc LT1 castings. The LT1 car ran more duration and if memory serves a lot less lift. They ran about the same times, both have managed 9.9 on aftermarket computers and very low 10s on stock computers.
The LT4 owner driver is a legend and undisputed racing and tuning guru, so it does not come down too experiance.
I will see if I can come up with what issue it was.
Old 08-14-2007, 08:41 PM
rob97ss's Avatar
I guess your talking about Ed wright and Ricks car,i read the article.Aug issue.
Quick Reply: LT4 Heads!!!
