biggest cam without machining heads
Well my 94 lt1 took a dump on me and am in the process of getting things together to freshen it up and cam it. so what do you say is the biggest lift i can get away with without having to machine the heads? if its less than .500 then what is the biggest cam that wouldnt choke on my stock heads. only have a home pocket port job on them.any advice would be very helpful.
Im running a 230/244 .544/.576 on a 112 in my car with no problems. I know people run bigger cams than that. It's not always about lift either, you have to consider duration. You can have a cam with alot of duration and not so much lift or vice versa and be alright. It all depends on what you want.
Originally Posted by speed_demon24
Lift has nothing to do with PTV clearance...
Originally Posted by Fastbird93
Oh I beg to differ. You're saying lift has nothing to do with PTV (Piston to Valve) clearance? Gee.......let's think about that one. It's not the only factor, but let's get real. Lift definitely has tie-in's with PTV clearance.
The LT1 has enough PTV that a 600 list cam should be fine. But you always want to check as PTV is closest normally just after TDC. I've installed a few 847, one using 1.6 rockers and the thinner Impala head gaskets and was still very close to 100 on the clearance. But those heads were cut for double springs that were for 650 lift.
Only spring I know of that will hadle 600 lift in the stock heads are the beehive. But I personally don't like going that close to the limits of the springs and coil bind, specially with a single spring. If it fails you run a real chance to take out the engine. For the installs I've done running the 306 or 847 with the beehives I used 1.5 rockers just for that little extra saftey.
If the heads are off the engine I would just spend the few extra dollars, have the seats cut and go with a nice double spring.
JB
JB
Why does everybody on here want to think large all of the time? If you want to run a nice cam that won't be starving with stock heads, look at something like the CC503. There are guys running very respectable times with this cam. It's all in the combo...no point running a huge cam without the head flow to support it to it's potential.
EDIT: There are always benefits to looking into a custom grind as well. You'll need some low-end to lug that Chevelle around.
WHY DO PEOPLE SUGGEST THE SAME CAMS?????????????//
CC cams,Hot cam,847
Lol
Because its proven technology. When i get some head work done i know im going custom!! There is so much more potential out there compared to the off the shelf grinds that people have been using for years.
yeah i am really trying to steer away from any machine work on the heads..mainly just want a proven , beefy cam that works well with unported heads. if i went custom...i would be totally lost... has there been problems with the beehive springs? i was actually leaning towards getting them ...
