High horsepower guys, what are you using for vacuum pump?
Nobody makes a belt driven vac pump for an lt1. I have seen electric but I doubt they would work on a high HP motor. I just use an Evac kit its better than just running breathers. I would suggest you call these guys they might be able to come up with something. I saw a real nice setup on an LS1 recently these guys make very nice stuff. http://www.gzmotorsports.com/vacuum-pumps.html
My coil is mounted there, guess I am gonna have to get creative.
I have a Ford crankcase evac pump from my old Ford days...just so damn BIG, part number M-9486-A460....gonna be hard to mount.
That Moroso pump looks MUCH smaller, I am gonna have to mount it low on the drivers side.
David
David
I use the moroso pump as well mounted on a custom bracket. Got the whole kit from Reher-Morrison complete with drive assembly for the crank, v-belt, pulley for the pump, pump, regulator and 12AN lines..... all i needed to do was fab up the bracket and i was done....
Can you dig me up part numbers, I need specs on that bracket, that a 3 or 4 vane pump? That setup is EXACTLY what I need, will work with my opti, coil mounted in factory location...you are THE MAN!!!!!!!!! Help a brutha out.
The # for the bracket is (707)429-1888 at California Street Machine and like i said the guys name is Lance. The only bad part is that he's on vacation right now in Mexico with his wife but he'll be home I believe the end of this week. Gives you some time to get the pump kit and then order it. Tell him that Jason gave you his name and you saw the bracket online. I told him that once I posted it people were going to want one like it.... So he's expecting some interest in it.... give him a call early next week and he can hook you up with pricing and build you one on the lathe...
Hey dave, just a side question totally unrelated but what length lokar cable did you get to work with your throttle body???? Reason i ask is because i have a lokar but it seems like it's way too long... and i don't want to waste money a second time...
